Hi after Migration to 3.5.10, problem at login.
The above exception was the direct cause of the following exception:
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/handlers/exception.py”, line 47, in inner
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/handlers/base.py”, line 181, in _get_response
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/views/decorators/csrf.py”, line 54, in wrapped_view
File “/opt/seatable/seatable-server-latest/dtable-web/seahub/saml/views.py”, line 94, in _decorated
return func(request)
File “/opt/seatable/seatable-server-latest/dtable-web/seahub/saml/views.py”, line 190, in acs
profile.save()
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/models/base.py”, line 739, in save
self.save_base(using=using, force_insert=force_insert,
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/models/base.py”, line 776, in save_base
updated = self._save_table(
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/models/base.py”, line 858, in _save_table
updated = self._do_update(base_qs, using, pk_val, values, update_fields,
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/models/base.py”, line 912, in _do_update
return filtered._update(values) > 0
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/models/query.py”, line 802, in _update
return query.get_compiler(self.db).execute_sql(CURSOR)
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/models/sql/compiler.py”, line 1559, in execute_sql
cursor = super().execute_sql(result_type)
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/models/sql/compiler.py”, line 1175, in execute_sql
cursor.execute(sql, params)
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/backends/utils.py”, line 66, in execute
return self._execute_with_wrappers(sql, params, many=False, executor=self._execute)
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/backends/utils.py”, line 75, in _execute_with_wrappers
return executor(sql, params, many, context)
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/backends/utils.py”, line 84, in _execute
return self.cursor.execute(sql, params)
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/utils.py”, line 90, in exit
raise dj_exc_value.with_traceback(traceback) from exc_value
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/backends/mysql/base.py”, line 73, in execute
return self.cursor.execute(query, args)
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/MySQLdb/cursors.py”, line 206, in execute
res = self._query(query)
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/MySQLdb/cursors.py”, line 319, in _query
db.query(q)
File “/opt/seatable/seatable-server-latest/dtable-web/thirdpart/MySQLdb/connections.py”, line 254, in query
_mysql.connection.query(self, query)
django.db.utils.IntegrityError: (1062, “Duplicate entry ‘vincent.dousset@symta.fr’ for key ‘profile_profile_contact_email_0975e4bf_uniq’”)
