I found a bug in the advanced statistics plugin when running in developer version.
Please check the following base: https://cloud.seatable.io/dtable/external-links/e04cb981cb044295be0a/
When you use the advanced statistics plugin, the heatmap will show you only this year as it is filtered in views filter1 and filter2.
filter1 filters for the last week, filter2 for 7 days ago and after. The latter doesn’t work in the developer version. When you export the view and test it in developer version the second heatmap shows all values unfiltered.
Please also mind the attached screenshots from cloud and developer version.
