when I group my rows in a view based on some colums, I always get a summary of values at the top of the groups. This does not make sense in some cases, can this be added as an option to change the setting per column?
e.g. I have a column with all start dates, using duration, a summary on the header just makes no sense, Same if I have a rate per hour in a column, the summary is useless and irritating for users, who don’t understand the logic.
You can disable the calculation of group results. Simply switch to “No calculation”.
Great, thanks, did not see the setting option.
