Timeout error occurs when executing a python script in the automation rule
  • SeaTable Edition (Developer or Enterprise)
    Enterprise
  • SeaTable Version (only necessary for self-hosted):
    You can find your SeaTable Server version at https://your-server-url/server-info
    4.4.9
Please describe your issue as precise as possible. If helpful, you can also provide:
  • API endpoints you used
  • Commands you executed (remove credentials)
  • Screenshots
  • Diagrams with Excalidraw
Error Messages:
If there are any error messages shown in the console or in the logs, please include them for better readability by wrapping them in a code block.
Script running for too long time!
Hello, SeaTable!
I tried to apply the functionality from Christoph’s tutorial on the Seatable Forum about getting an email address from a user column to an automation rule.
https://forum2.seatable.io/t/tutorial-get-email-address-from-creator-collaborator-last-modifier-column/1610
When I run the Python script manually, it executes and completes within a second without any issues. However, when I configure it to run as an automation rule triggered by a row modification, a timeout occurs, and the script fails to execute.
Is there a solution to this problem?
logs
Can you send the script (ideally embedded in a shortened and anonymised copy of the base) to support@seatable.io for analysis?
Hello!
If you are referring to the Python source code, I used the same source code which is written by Christoph.
Can you please check your automation trigger?
I assume that you created an automation loop:
  • the row is modified → automation is triggered
  • the automation modifies the row → automation is triggered
You see the point?
Update your automation trigger to make sure that the automation only ran once.
Please report back, if this solved your problem.
