Hey, due to an issue with the automation of SeaTable, and because it doesn’t work automatically, we have to manually create (or update) a link between two tables every day.
To ensure this works even when our responsible employee is unavailable, I would like to write a Python script to handle this task.
Das habe ich auch erfolgriech geschaft:
def link_rows(self, table1_name, table2_name, link_column, key_column):
Link rows between two tables based on a common key column.
try:
link_id = self.get_link_id(table1_name, link_column)
except Exception as e:
raise Exception(f"Failed to get link ID: {e}")
try:
table1_data = self.get_table(table1_name)
table2_data = self.get_table(table2_name)
raise Exception(f"Failed to retrieve table data: {e}")
try:
table2_dict = {row[key_column]: row['_id'] for row in table2_data}
except KeyError as e:
raise Exception(f"Key column '{key_column}' not found in table '{table2_name}': {e}")
row_id_list = []
other_rows_ids_map = {}
for row in table1_data:
employer_id = row.get(key_column)
if employer_id in table2_dict:
row_id_list.append(row['_id'])
other_rows_ids_map[row['_id']] = [table2_dict[employer_id]]
try:
result = self.base.batch_update_links(link_id, table1_name, table2_name, row_id_list, other_rows_ids_map)
print(result)
print("Linking successful")
raise Exception(f"Failed to link rows: {e}")
Now, we are working with tables that have 40,000 or more entries, but using get_table
and list_rows
, I can only retrieve 1,000 entries at a time. At the same time, I don’t want to increase the number of requests since we have a daily limit.
I’m not sure if the same limitation applies to batch_update_links
, but I assume it does.
Is there a solution for pulling and linking large datasets in Python or JavaScript?
