Hello
I’m facing an issue with Seatable that’s been puzzling me. Whenever I try to sync a large dataset from a CSV file, the process consistently fails midway through with a ‘Connection Timeout’ error. I’ve rechecked that my network connection is stable, and I’ve tried the sync process multiple times with the same result.
Has anyone faced a similar issue before, and if yes, how did you resolve it? Any tips would be greatly appreciated.
Thank you for your help!
Thank you
gregbowers
