To get the value from a previous row is most of the time only possible by using javascript or python.
Here is one option to connect two or more rows via linked column and automation rules.
Create a table with a date column.
For example, if you have monthly records you will have entries like 2023-01, 2023-02, 2023-03 and so on. -
Create a new „Link to other records column“, select the same table and give it the name „Previous row“
Now you have to create two other formula rows for comparison. The first row creates a string with the year and month of the current date and the other row contains the string of the previous month.
First column:
Formula:'Y' & text(year({Date})) & 'M' & text(month({Date}))
<< will create Y2023M1
Second column:
Formula:'Y' & text(year({Date}) - if(month({Date}) = 1, 1, 0)) & 'M' & text(if(month({Date}) = 1, 12, month({Date}) - 1))
<< will create Y2022M12 -
Now you can create an automation rule that can compare the values and find the related previous month link
Event: Records meet specific conditions after modification
Automated action:
Add links
Select link column in the table: Previous row
if column: Previous month
column: Current month
Save the rule
Every new row after selecting a date in the Date column will search for the previous month row.
And you can create Link formula columns to get previous values.
