yblis
March 18, 2024, 7:36pm
1
I would like to know if you have a new procedure for installing Python libraries. Indeed, with the old version, I had created a bash script that allowed me to install Python libraries, but since the recent updates, this no longer works.
Can you provide us with the new instructions?
Thank you in advance.
yblis
March 18, 2024, 9:02pm
2
I’ve found it
Here’s an example for the ldap3 library:
Pull the image
docker pull seatable/seatable-python-runner:latest
Activate a container and name it “add-libs” from the backend.
docker run -d --name="add-libs" seatable/seatable-python-runner custom
Enter the container
docker exec -it add-libs sh
Install the third-party package or do some other modification, quit the container after you finished.
/settings # pip install ldap3
You can add other Python libraries.
Exit the container
/settings # exit
Commit the new image
docker commit -m "add APPS" --change "CMD null" add-libs seatable/seatable-python-runner:APPS
Apply the new image
Modify the following variable in ./seatable_python.yml in the python-starter container:
PYTHON_RUNNER_IMAGE=seatable/seatable-python-runner:APPS
Up container:
docker-compose up -d
Purge:
docker stop add-libs && docker container rm add-libs
system
Closed
March 20, 2024, 9:03pm
3
