Unique view names fail when duplicating views
Hi SeaTable-Team.
I’ve dicovered a bug I’d like to share with you.
When you have a view with the name “test” and you create a new view with the same name the app will tell you that there already is a view with that name. So far so good.
But when you duplicate a view and put in the same name as the existing one, the unique validation will fail. You can create as many views with the same name as you want.
Greetingz
AkDk7
Thank you for your feedback. :smiley:We will fix it in the next version.
Awesome. Thank you very much :slight_smile:
