In calendar and timeline plugins we need to select a “Single Select” field as Color field for elements.
By default, (for calendar at least), it selects the first “Single Select” field for colouring.
I thinks that Seatable should use **by default", the condition based styling defined in the selected view. We could then override it with a “Single Select” field. But the condition based styling should be proposed to choose from and selected by default.
What do you think ?
Thanks.
