I have created a webhook and would like the trigger to only fire when the “Write” option is selected in the single select. However, for example: ‘column_name’ or ‘Column_type’ are grayed out.
Is this because these functions are not enabled in the Free Plan?
Webhooks do not trigger conditionally.
This is not supported.
Instead, you must filter the webhook’s content.
Aha. Ok, Thank you very much.
