XRechnung with SeaTable?
Hello everyone,
is it possible to implement the topic “E-Rechnungspflicht” or “XRechnung” with SeaTable in the future?
Yes, I used a Phyton script for this task
Can you explain in more detail how you do this or what exactly you do? Thank you.
A phyton script reads out the xml file and puts the data into the correct seatable column.
Ok thanks, that would be the way to go if I get an XRechnung but is it also possible to create one that companies can then read out?
We, SeaTable, will be looking into it in 2025. For now, it’s no priority topic for us.
Ask AI, it will support you with scripts
Ok thanks for all information. Sounds like an exciting project.
