I use A SeaTable Database to collect places, therefore I need the column “geoposition” and I use it with coordinates.
In the View on the SeaTable Website (Cloud) I get the coordinates in the right order and the map shows all locations on the right position. But when I export the data or when I do copy & paste, then the coordinates (longitude and latitude) are changed and locations in Germany suddenly are between Ethiopia and Jemen. Is there a way to avoid this change?
We will check the issue.
