Currently I’m working with longer HTML and other script snippets to do some scraping and ChatGPT stuff.
Now I use the Long Text field because I need to see the whole text snippets visually which is a pain with the (short) text fields because of its size.
Unfortunately, the Long Text field does some formatting, which I do not need in this case. I just want to see end edit the content in raw text or in “source view” like some other web text editor supports.
So really helpful would be:
The ability to switch the Long Text column to a “no formatting mode” or
a mutiline text field as Column type, without any formatting that can be edited in a popup with a larger editor (like the Long Text)
Is this currently possible and I don’t get it how to do that?
I’m asking because I found another topic that requests the same:
In that topic, someone with a SeaTable Badge states a Feature Request has been added for this request, but I cannot find it in the list of feature requests here: https://ideas.seatable.io/
So has this feature already be implemented? Or should I add a new feature request?
The topic you’re referring to is from 2021. At this time https://ideas.seatable.io did not exist. Therefore, I would recommend that you create a new issue at ideas.seatable.io.
Actually this can be easily solved by putting your text in a code element of Long Text field. (Just add a new line of “```” in the beginning of your text and end of your text)
The long text field using Markdown format. By putting text in a code element, you can preserve the original content.
