My sealfhosted Seatable was working fine at version 1.8.0. After upgrading from 1.8.0 to 2.0.0 seafile shows a client side error 500 (for route api/v2.1/workspaces/
) when loading base view
dtable_web.log states
2021-05-28 13:03:32,366 [ERROR] seahub.api2.endpoints.dtable:154 get (1146, "Table 'dtable_db.folders' doesn't exist")
2021-05-28 13:03:32,367 [ERROR] django.request:228 log_response Internal Server Error: /api/v2.1/workspaces/
also loading “Gemeinsamer Datensatz” (api/v2.1/dtable/common-datasets/?by_group=true
fails with erro 500
dtable_web.log:
2021-05-28 13:09:03,549 [ERROR] django.request:228 log_response Internal Server Error: /api/v2.1/dtable/common-datasets/
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/backends/utils.py", line 84, in _execute
return self.cursor.execute(sql, params)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/backends/mysql/base.py", line 71, in execute
return self.cursor.execute(query, args)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/MySQLdb/cursors.py", line 206, in execute
res = self._query(query)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/MySQLdb/cursors.py", line 319, in _query
db.query(q)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/MySQLdb/connections.py", line 259, in query
_mysql.connection.query(self, query)
MySQLdb._exceptions.OperationalError: (1054, "Unknown column 'dtable_common_dataset.group_id' in 'field list'")
The above exception was the direct cause of the following exception:
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/handlers/exception.py", line 34, in inner
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/handlers/base.py", line 115, in _get_response
response = self.process_exception_by_middleware(e, request)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/handlers/base.py", line 113, in _get_response
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/views/decorators/csrf.py", line 54, in wrapped_view
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/views/generic/base.py", line 71, in view
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 509, in dispatch
response = self.handle_exception(exc)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 469, in handle_exception
self.raise_uncaught_exception(exc)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 480, in raise_uncaught_exception
raise exc
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 506, in dispatch
response = handler(request, *args, **kwargs)
File "/opt/seatable/seatable-server-latest/dtable-web/seahub/api2/endpoints/dtable_common_dataset.py", line 68, in get
available_sets = [dataset for dataset in datasets if dataset.can_access_by_user_through_group(username)]
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/models/query.py", line 274, in __iter__
self._fetch_all()
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/models/query.py", line 1242, in _fetch_all
self._result_cache = list(self._iterable_class(self))
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/models/query.py", line 55, in __iter__
results = compiler.execute_sql(chunked_fetch=self.chunked_fetch, chunk_size=self.chunk_size)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/models/sql/compiler.py", line 1142, in execute_sql
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/backends/utils.py", line 67, in execute
return self._execute_with_wrappers(sql, params, many=False, executor=self._execute)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/backends/utils.py", line 76, in _execute_with_wrappers
return executor(sql, params, many, context)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/db/utils.py", line 89, in __exit__
raise dj_exc_value.with_traceback(traceback) from exc_value
db.query(q)
django.db.utils.OperationalError: (1054, "Unknown column 'dtable_common_dataset.group_id' in 'field list'")
My upgrade procedure was:
down-compose down
- edit image tag in docker-compose.yml to 2.0.0
docker-compose pull
docker-compose up
and wait forThis is a idle script (infinite loop) to keep container running.
docker-compose up -d
docker exec -d seatable /shared/seatable/scripts/seatable.sh start
